1998 5.7
Remove upper radiator fan shroud.
Unload power steering pump belt tensioner and remove belt.
Place drain pan under steering pump.
Disconnect return and feed lines from pump
Cap end of lines and pump fittings.
Remove bracket mouthing nuts.
Remove bracket.
Remove pulley from pump shaft, (you will need a PS pulley remover that you can rent at most auto parts stores if you don't have one, most of the time it's basically free, you leave them a deposit on the tool and then get your money back when you return it.)
Remove pump mounting bolts
Remove pump
Install in reverse procedure.
Use pulley installer to install pulley, (same deal with renting one from the parts store)
Install pulley flush with end of pump shaft +/- 0.010"
Friday, July 3rd, 2009 AT 9:47 PM
