1995 Chevy Suburban tail lights - brake lights only
MBERG98
  • 1995 CHEVROLET SUBURBAN
Electrical problem
1995 Chevy Suburban V8 Two Wheel Drive 147000 miles
blinkers work, center light on roof works - no brake lights on left or right-
changed bulbs and right side assy that bulb plugs into-
looked at fuses- all look good-
which # fuses are the one or ones for tail light?
Wednesday, August 6th, 2008 AT 4:33 PM
MASTERTECHTIM
  • 4,750 POSTS
If you have no brake lights but the third brake light works and the blinkers work then either you have a bad brake light switch. The switch has 2 outputs on it, one for the third brake light and the other wire feeds the directional switch. So check white wire from brake light switch where it feeds into the bottom of steering column at the directional switch plug, if you have power on the white wire there when the brakes are applied then the directional switch is the problem causing the brake lights not to work.
Thursday, August 7th, 2008 AT 7:41 PM
