1995 Chevy Suburban Break lights not working
JACEJA10
Brakes problem
1995 Chevy Suburban Four Wheel Drive Automatic 202000 miles
I just bought a 1995 Chevy Suburban. When I first bought it the break lights were not working and the repair man from where i purchased it fixed that issue but now the break lights don't work again. I am not an expert in cars so any suggestions as to what it can be is greatly appreciated.
Aug 8, 2010 at 12:41 PM
  • 75,988 POSTS
Hi jaceja10, Welcome to 2carpros and TY for the donation
Check and test the stop/haz fuse no1 15amp in the fuse block lower left side of dash if okay test the brake switch follow the brake pedal arm till it meets the brake support bracket the switch is here-if okay
Does the high mount brake light works? If so
Get the turn and hazard checked/tested out-the bottom brake lights circuit goes thru this switch
Aug 8, 2010 at 6:20 PM
JACEJA10
Thanks guys for all your help but unfortunately I am not very good at fixing cars so I am so lost when it comes to doing what it is that you have recommended that i do. Do any of you know if there is a website that can help me with pictures or diagrams of what I am supposed to do?
Aug 10, 2010 at 4:42 AM
