1992 Chevy Suburban DIES WHILE DRIVING
D CARTER
  • 1992 CHEVROLET SUBURBAN
  • V8
  • 4WD
  • 189,000 MILES
I JUST PUT IN A NEW FUEL PUMP, FILTER.
WHEN IT IS COLD IT WILL START AND RUN BUT AFTER IT WARMS UP IT WILL DIE AND NOT WANT TO START, SEEMS LIKE IT IS STARVING FOR FUEL. IM LOST
Tuesday, October 27th, 2009 AT 9:50 AM
JDL
  • 16,098 POSTS
Welcome to the forum, any trouble codes? If the coolant temp sensor is faulty, it can cause a lot of problems? I mention that because your problem seems to be temp related. Also, you might use a gage and check fuel pressure.
Tuesday, October 27th, 2009 AT 10:34 AM
