Slow starting
DSTEPH1
I have a 2000 Chevy Silverado 1500 5.3L automatic. It is a 2wd 3dr. It has 90000 miles on it.
The battery is good. The alternator is good. The starter is working. I have replaced the fuel filter. It will start after pumping the gas. I can shut it off and it will start immediately every time. If it sits it will take several tries to restart by pumping the gas.
I suspect the fuel pump, costly. Is there any other ideas as to the problem. I have only gone through 2 sets of tires and one battery in 7 years. Never had any problems before.
Appreciate any ideas.
Sep 4, 2007 at 8:09 AM
  • 75,988 POSTS
[quote:8f4165011b="dsteph1"]I have a 2000 Chevy Silverado 1500 5.3L automatic. It is a 2wd 3dr. It has 90000 miles on it.
Appreciate any ideas.[/quote:8f4165011b]
Check the fuel pressure-could be a FPR/PUMP/leaking injectors.
Sep 4, 2007 at 8:17 AM
  • 75,988 POSTS
You need a fuel pressure gauge or try this pinch off the return line and see what happens.
Sep 4, 2007 at 8:45 AM
