2000 Chevy Silverado No Idle Hard Start Fix
SUNDOGUSA
2000 Silverado 2500 4x4 6.2L 111,300 mi
Truck started to act up recently. Engine will not idle. Difficulty starting. Need to try to startt several times and finally starts after pumping the gas pedal.
Occasionally, turning key causes everything to blackout, as in no lights, no radio, no dash display. After a few seconds an audible reset is heard, then the engine strating routine happens. Pump the gas pedal engine might start after 4-5 try.
No engine codes on a code reader.
I see possibles are ignition switch, fuel pump, pressure regulator. Also saw a "replace battery." Battery was checked and it is very good.
Any ideas on how to narrow down what might be wrong?
Thanks for any help.
Jan 28, 2007 at 6:04 AM
2CARPRO JACK
  • 11,533 POSTS
Definitly clean all battery connections real good.Yes, the fuel pressure reg can do that as well.Look for corrosion on relays and connectors at main power center under the hood
Jan 28, 2007 at 11:39 PM
SUNDOGUSA
Thanks for the reply. Battery terminals are OK. This AM truck "blanked out" but then just at the last instant tried to start. I suspect the ignition switch. I will also check fuel regulator.
Thanks.
Jan 28, 2007 at 11:58 PM
SUNDOGUSA
Cleaned Battery terms. That fixed the "blanking out" problem. Sorry to say the battery terminals were in bad shape.
Fuel pump was shot.
Fuel regulator was leaking.
All repaired/replaced.
Truck runs fine.
Jan 31, 2007 at 3:44 AM
Suggested Repair
Clean battery terminals and connections, inspect underhood power-center relays and connectors for corrosion, and replace a failed fuel pump and leaking fuel pressure regulator.
Conversation Summary
A 2000 Chevrolet Silverado 2500 would not idle, was hard to start, and sometimes lost all electrical power when the key was turned. No codes were present and the battery tested good. The expert advised cleaning battery connections, checking the fuel pressure regulator, and looking for corrosion at the underhood power center. Cleaning badly corroded battery terminals stopped the electrical blackouts. A failed fuel pump and leaking fuel regulator were also replaced, after which the truck ran fine.
