When I run my heater, the fan squeals. Can I repair this by lubricating the motor shaft? where is it located?
Thanks for helping
Feb 15, 2007 at 4:17 AM
CHEVY22
✓Experienced Mechanic
you can try it but most likely you will be replacing it , they are not expensive and easy to replace , right side of engine compartment at the firewall look for a round object with approx 6 bolts in it,
