2004 Chevrolet Silverado Coolant in Oil
JUDEIRVIN
I got a 2004 Silverado 1500 5.3L with 79,000miles. Several months ago it started smoking on start up. I changed the oil and noticed it was sludgy. I also noticed that the coolant level was low. I thought it was obvious that it had an internal coolant leak. I took it to the local Goodyear place and had them take a look at it, and they said it needed a new water pump, theromostat, radiator, and upper and lower hoses. Now, all I can assume is that they did the compression checks and found nothing out of the ordinary. I was thinking head gasket or cracked head, Can coolant mix with engine oil through a faulty water pump?
Oct 21, 2007 at 9:24 PM
  • 75,988 POSTS
Can coolant mix with engine oil through a faulty water pump? No
Coolant in oil and Oil in coolant comes from a blown gasket.
Oct 21, 2007 at 11:25 PM
Suggested Repair
A faulty water pump does not mix coolant with engine oil. Coolant in the oil, or oil in the coolant, points to a blown gasket; diagnose and repair that gasket leak rather than treating the water pump as the cause.
Conversation Summary
The owner of a 2004 Chevrolet Silverado 1500 5.3L reported startup smoke, sludgy oil, and low coolant and suspected an internal coolant leak such as a head gasket or cracked head. A shop recommended a water pump, thermostat, radiator, and hoses. The expert said a faulty water pump cannot mix coolant with oil, and that coolant in the oil or oil in the coolant comes from a blown gasket.
