2003 Chevy Silverado P0449 EVAP Code
CADEDDIE
  • 8 POSTS
2003 silverado 5.3 liter extended cab 7z1 with 80,000 mil. I have a p0449 code. I know what it mean already I have done my research but how should I approach this problem and where on the truck is this located. Maybe tell my where to find a schamatic for this problem. Im not asking much am I...lol
Thanks
Eddie Rdz
Mar 1, 2007 at 7:10 AM
CHEVY22
  • 1,375 POSTS
the evap solenoid is located on the right front of the fuel tank, yeah its a bear , and the tests you really need a scanner to open and close the valve , but you can check power and ground to the solenoid just to make sure its being fed and its not a blown fuse
jim
if you are happy with the info please leave feedback we all here do this for free feedback is a way of saying thank you for the help
Mar 1, 2007 at 7:25 AM
CADEDDIE
  • 8 POSTS
I will check it out.
Mar 1, 2007 at 7:32 AM
CHEVY22
  • 1,375 POSTS
ok let me know
jim
Mar 1, 2007 at 7:35 AM
CADEDDIE
  • 8 POSTS
one more thing. where do I find the fuse for the solenoid?
Mar 1, 2007 at 7:37 AM
CHEVY22
  • 1,375 POSTS
tell you the truth i cant find it anywhere , ive been over the whole trucks harness and i dont see one, well if all else fails check power and ground , if you have both brfore the sol your ok
jim
Mar 1, 2007 at 7:59 AM
CADEDDIE
  • 8 POSTS
I will give it a try.
Eddie R.
Mar 1, 2007 at 8:38 AM
Suggested Repair
Locate the EVAP vent solenoid at the right front of the fuel tank. Use a scan tool to command the valve open and closed, and check power and ground at the solenoid. A dedicated fuse was not identified, so confirm supply and ground before replacing the solenoid.
Conversation Summary
The owner of a 2003 Chevrolet Silverado 5.3 with about 80,000 miles has a P0449 code and asked where the related part is and how to approach diagnosis. The expert said the EVAP solenoid is on the right front of the fuel tank and is difficult to access. They recommended using a scanner to open and close the valve and checking power and ground, noting they could not find a dedicated fuse. The owner said they would check it.
