2002 Chevy Silverado P0101 MAF
JERRY DANDENEAU
Have a 2002 Chevy 2500 HD 4wd auto,50,000. The code is for MASS OR VOLUME AIRFLOW CIRCUIT RANGE/PERFORMANCE PROBLEM. I did install a K & N air intake kit last year. Things to check for or do?
May 24, 2007 at 5:19 AM
SERVICE WRITER
  • 9,123 POSTS
Keep in mind that after a successful repair on this, it will take 3 consecutive ignition cycles and passing tests on this for the light to go off.
Check for any leaks or loose air snorkel connections. You can try cleaning the MAF with electrical cleaner, allowing it to dry completely before re-installing.
May 24, 2007 at 2:20 PM
Suggested Repair
Check for intake leaks or loose air snorkel connections. Clean the MAF sensor with electrical cleaner and let it dry completely before reinstalling. After a successful repair, the light may need three consecutive ignition cycles with passing tests to turn off.
Conversation Summary
The owner of a 2002 Chevrolet Silverado 2500 HD has code P0101, a mass airflow circuit range/performance problem, after installing a K&N intake. The expert advises checking for leaks or loose snorkel connections and cleaning the MAF with electrical cleaner, allowing it to dry fully before reinstalling. The warning light may take three passing ignition cycles to go out.
