1989 Chevy Silverado Code 44 Lean Surge Fix
CHEVYMANCALI
hey all....
i have a 1989 chevy 4x4,2500 6 lug,automatic trans.. the truck has a new engine in it with less than 6000 miles on it (goodwrench HO 350) ( dont know the actual milege of the truck itself as i bought it used about a year ago and the odometer doesnt work). one day about 2 weeks ago i was up deer hunting and the check engine light popped on, and the thing started surging real bad ,no power,etc,etc. i drove it home ( about 15 miles away) and took it to my neibor and mechanic. keep in mind that the truck generally runs like it just came off the showroom floor.
now, we checked the trouble code, and it read that it was running real lean ( code "44"). he hooked it up to his diagnostic machine, and it said that it wasnt getting the O2 it should so we replacxed the O2 sensor. no good. so far we have replaced
O2 sensor
temp sensor
MAP module
intake gaskets ( it had a small leak)
computer ( plugged in a new one and tested it,same thing,no change)
fuel filter
throttle body base gasket
fuel pump in the tank ( which we havent checked yet, and it could be causing it i suppose)
i got it back yesterday and it ran like new again. this morning, i took off to go hunting AGAIN and i got about 10 miles from home and the light popped on AGAIN and it started running real crappy and surging AGAIN.....
now, like i said, the truck ususally runs like brand new.
all the diagnostic computer stuff says everything fine,exept its running lean and the computers trying to compensate for the problem by spraying more fuel thru the injectors ( throttle body injected of course). im on social security and cant keep pumping money out just replacing things in the hopes that it will fix it.
any suggestions'?
Sep 26, 2007 at 3:21 AM
FISHERMAN
  • 937 POSTS
Running lean...
Check the spray pattern on the injectors ..
Could be a clogged injector....
or malfunction injector
let us now if you test them...
Sep 26, 2007 at 4:54 AM
CHEVYMANCALI
[quote:c510fc4fdc="fisherman"]Running lean...
let us now if you test them...[/quote:c510fc4fdc]
injectors were checked ( both good) and replaced (with new ones) just to see if that was the problem-no change.
im having him pull the fuel tank and replace the fuel pump today just to make sure. that might be it. i may be wrong, but im thinking if the fuel pump isnt workng properly that the computer might seee it as a "lean" situation and attempt to enrichen the system leading to the surging
OH, by the way, the computers trying to enrichen the system,seeing it as lean when it is seemingly pumping the correct amout of fuel its enrichening the system to the point you can smell the gas in the xaust.. i had a guy email me and say that it might be the IAC ( ANOTHER new part i forgot to list) OR possibly the fuel pump ( his reasoning was that if the fuel pump is not putting out the factory presure that even though its getting gas that it would possibly see it as a "lean" situation)
Sep 26, 2007 at 5:33 AM
FISHERMAN
  • 937 POSTS
[quote="ChevyManCali"][quote:19bc9a291b="fisherman"]Running lean...
let us now if you test them...[/quote:19bc9a291b]
OH, by the way, the computers trying to enrichen the system,seeing it as lean when it is seemingly pumping the correct amout of fuel its enrichening the system to the point you can smell the gas in the xaust.. i had a guy email me and say that it might be the IAC ( ANOTHER new part i forgot to list) OR possibly the fuel pump ( his reasoning was that if the fuel pump is not putting out the factory presure that even though its getting gas that it would possibly see it as a "lean" situation)[/quote
IAC= Idle Air Control
Well did you check the pressure on the gas line before pull out the pump?
Also: did you check the pressure regulator?
Could be that the pressure its not regulated at the correct PSI...
Sep 26, 2007 at 7:04 AM
CHEVYMANCALI
nope, didnt check it myself, but i called him and told him to check it, and hes supposed to. ill let you know what he finds
Sep 26, 2007 at 7:40 AM
CHEVYMANCALI
we found it was the fuel pump. thanks for the replies
Sep 27, 2007 at 2:13 PM
Suggested Repair
Verify fuel-line pressure and the fuel-pressure regulator before replacing parts. The confirmed fix was a faulty fuel pump.
Conversation Summary
A 1989 Chevrolet Silverado 2500 with throttle-body injection set lean code 44 and surged with low power after running normally. Many parts, including the oxygen sensor, sensors, computer, gaskets, and injectors, were replaced without lasting improvement. The expert advised checking injector spray, fuel pressure, and the pressure regulator. The owner later confirmed the fuel pump was the cause.
