2003 Chevrolet Silverado Knock on Turn
RYAN.THOMAS
I have a 2003 silverado Z71 67,000 miles 5.3 v8. My question is that when I turn the wheel to the right there is a knocking noise. A couple of months ago I was hearing this noise and I had the left front wheel assem. replaced. The noise went away for a while and now its back. Do you think that the right needs to be replaced know. If so is this a common thing. Thanks alot.
Feb 15, 2007 at 1:38 AM
SERVICE WRITER
  • 9,123 POSTS
wheel assy? What exactly are you referring to?
Rim?
Wheel bearing/hub?
Feb 15, 2007 at 4:08 AM
RYAN.THOMAS
[quote:088336be9f="Service Writer"]wheel assy? What exactly are you referring to?
Rim?
Wheel bearing/hub?[/quote:088336be9f]
I WAS REFERRING TO THE WHEEL BEARING/HUB. THANKS FOR FEEDBACK
Feb 15, 2007 at 4:57 AM
SERVICE WRITER
  • 9,123 POSTS
It wouldn't surprise me, the left side and right side have the same amount of turns and milage etc. Yer welcome on the feedback.
https://images.2carpros.com/forum/automotive_pictures/30961_bigsmile1_1.jpg
Pretty sad that you have 67,000 and it went huh?
Feb 15, 2007 at 7:28 AM
  • 55,743 POSTS
Have you replace the inter shaft from the colum to the box, chevy has a pile of them at the dealer. I have the same truck, mine did that to.
Feb 16, 2007 at 7:04 AM
Suggested Repair
Inspect the steering intermediate shaft from the column to the steering box, a known wear item on this truck, and also check the right front wheel bearing/hub since the left hub was already replaced and both sides have similar mileage.
Conversation Summary
A 2003 Chevrolet Silverado Z71 with a 5.3 V8 knocks when the wheel is turned right. The left front wheel bearing/hub was replaced earlier and the noise returned. One reply said the right hub could fail the same way; another recommended replacing the intermediate shaft from the column to the steering box, a common dealer part on this truck.
