2001 Chevrolet Silverado Growling Noise
SILVERADOGIRL13
Lately I've been hearing a "growling" noise coming from the driver side front. I've asked around and what I'm hearing is the ball joint/wheel bearings ..does anyone have a suggestion as to what this might be. 2001 2wd 4.3 silverado approx 84000km's
Feb 17, 2007 at 2:49 AM
CHEVY22
  • 1,375 POSTS
check the front end , wheel bearings and ball joints , ball joints wont growl , but they need to be checked anyway , jack that thing up in the front and give the wheels a spin by hand and see what you hear , it could also be in the front diff but start simple
and be careful
jim
Feb 17, 2007 at 7:12 AM
Suggested Repair
Jack up the front end and spin the wheels by hand to locate the growl. Inspect the wheel bearings and ball joints; ball joints usually do not growl but should still be checked. Start with those simple checks before considering the front differential.
Conversation Summary
The owner of a 2001 Chevrolet Silverado 2WD reports a growling noise from the driver-side front and suspects a ball joint or wheel bearing. The expert recommends checking the front end, spinning the wheels by hand while the truck is jacked up, inspecting the bearings and ball joints, and considering the front differential only after the simpler checks.
