I lost low beam headlights. Once in a while they come on for a short time but not for long. The high beams work fine. What could this be?
Jun 7, 2007 at 12:00 PM
JAVA MOTORSPORTS
MEMBER
Check the connectors at the headlights move the corrector around with the lights on low beam sometimes the connectors will lose connection. If that don't work you may have a bad light switch almost always the problem. Also check the fuse if it is not getting a good connection they will not work or will till you hit a bump and then go out. 8)
Jun 9, 2007 at 3:41 AM
SC1 RACING
✓Experienced Mechanic
check the ground on radiator support for loose or corrosion. the high are on a diff circut.
