I lost low beam headlights. Once in a while they come on for a short time but not for long. The high beams work fine. What could this be?
Jun 7, 2007 at 12:00 PM
Check the low-beam ground on the radiator support for looseness or corrosion, since the high beams are on a separate circuit. Also inspect the headlight connectors, headlight switch, and fuse for poor connections.
The owner of a 1995 Chevy Silverado reported intermittent low-beam failure while the high beams continued to work. Suggestions included checking the headlight connectors, headlight switch, and fuse connection, and specifically inspecting the radiator-support ground for looseness or corrosion.
