4WD front end noise on coast
CJCH21
  • CHEVROLET SILVERADO
2000 Model Chevy Silverado 4x4. 135000 miles. 4.8L v8. On coasting the vehicle, I am noticing a whining noise that becomes more like a gear gnashing as the ground speed drops from higher to lower. Could this be caused by front hubs not unlocking? T-case is manual. Could the linkage be loose? Seems like the focal point of the noise is under the front end of the truck, slightly off center to the right. Could this simply be low fluid (Haven't checked it yet) or is this something more complex? I recently replaced the rear differential gears with the same ratio. Any help would be greatly appreciated!
Left a small thank you with you guys. Hope it helps a little.
Wednesday, October 31st, 2007 AT 8:37 AM
2CARPRO JACK
  • 11,533 POSTS
Your truck doesnt have locking hubs, it is all done in th efront diff. If you just replaced the gears, and now hear a grinding style noise I wouldnt drive it any more til the problem is found. Did you follow a service manual when you regeared the front diff? Check to see if the pinion is loose.
Thursday, November 1st, 2007 AT 7:39 AM
CJCH21
Never regeared the front diff. I've only done the rear.
Thursday, November 1st, 2007 AT 7:41 AM
