Front end noise? CV joint? Bearing? Differential?
MOODYBOOTY_2003
  • CHEVROLET SILVERADO
I have a 2001 Z71 extended cab with a 5.3 motor and auto tranny. With push button 4 wheel drive. I can hear a popping noise in my front left wheel when usually turning but sometimes straight line driving. Its not a real loud popping noise but really more like a clicking. It seems to be worse in the mornings when its cool. I just replaced the cv joint and inner tie rod because it had a little slack in it. While doing this I drained my front differential fluid and my magnetic plug had some shavings on it. Before replacing the cv joint I was hearing this clicking noise and also had vibration when braking. I thought it was the cv joint the whole time but now I don't know. The vibration has quit since the new cv shaft but the clicking noise is still there if not worse. The only other options are my wheel bearing or my front differential so I was wandering what your opinion was on it and if there might be a bearing in the front differential that might be bad. Thanks
Monday, October 29th, 2007 AT 4:56 PM
2CARPRO JACK
  • 11,533 POSTS
Most likely the wheel bearing(hub). Especially if it has bigger than stock tires. The hubs cant handle it too well
Monday, October 29th, 2007 AT 6:09 PM
MOODYBOOTY_2003
I don't really have bigger tires just went from 265 stock tires to 275's. Dont think that would hurt anything. Is there any way to check the wheel bearing, I tried moving it to see if there was any slack and couldnt really feel any. I also forgot to mention that my torsion bars were turned up to level out the front end. Thanks for your responses.
Monday, October 29th, 2007 AT 9:04 PM
2CARPRO JACK
  • 11,533 POSTS
Did you lift up the truck when you checked it? Need to get the weight off it and then see if it has any top-bottom play in the wheel
Tuesday, October 30th, 2007 AT 7:55 AM
