2006 Chevy Silverado Headlights
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEITHLAXTON
The headlights will not turn on. The highbeams and all other lights are working fine. I checked fuses i think it might be a switch. How could i determine if the switch is the problem. I tried switching the relays and they still didnt work.
Jan 30, 2010 at 3:56 AM
TOOOMANYTOYS
  • 513 POSTS
The low beams and high beams both run through the switch. Its unlikely that it is the switch since the high beams work. I would try swapping the relays from high beam to low beam.
Jan 30, 2010 at 4:10 AM
KEITHLAXTON
i tried switching them and headlights still won't come on high beams did work so its not relay any other suggestions?
Jan 30, 2010 at 4:26 AM
TOOOMANYTOYS
  • 513 POSTS
Have you checked voltage at low beam side of socket. If there isnt any voltage you may need to get ahold of a scanner to see if the body control module is sending input to circuit.
Jan 30, 2010 at 4:51 AM
SCOTTY DEE
  • 592 POSTS
Test the headlamp dimmer switch circuit for a short to ground. Dimmer switches are prone to failure on these.
Jan 30, 2010 at 11:23 AM
