1999 Chevy Silverado No low beams but I do have high beams
1999 CHEVROLET SILVERADO
100,000 MILES • V8 • 4WD • AUTOMATIC
TABITHA8866
I have replaced both bulbs even though they didn't need it and have check all the fuses. I am wondering if it could be the headlamp switch? I do not have my daytime running lights either. I do have tail and brake lights and all the blinkers are working .
Sep 23, 2009 at 8:44 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
check the daytime running light (DRL) relay located on the convenience center.
Sep 23, 2009 at 9:52 PM
TABITHA8866
checked the DRL relay it is fine. Have since changed the headlamp switch, which did absolutely nothing. Still only have high beams.
I have also had intermitten problems with the odometer not lighting up either could these two be related?
Sep 25, 2009 at 10:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
also check the headlamp relay in underhood bussed electrical center
Sep 25, 2009 at 6:46 PM
TABITHA8866
have checked the drl relay also still no low beams. All fuses are fine. I do not understand why it just happened out of the blue like this. What else can I check. there has to be something I am missing.
Oct 5, 2009 at 1:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
do you have a separate switch for brighting / dimming the headlamps and turning on / off the headlamps? if so then the dimmer switch could be faulty
Oct 5, 2009 at 3:52 PM
