2000 Chevy Silverado front end vibration at 100k
2000 CHEVROLET SILVERADO
148,500 MILES • V8 • 4WD • AUTOMATIC
ALEC TRICIAN
My 3/4 ton starts to growl and vibrate in the front end between 98 and 105 Kmh? once I let my foot off the growl/vibration stops. Not much 4 wheeling but I do use the truck with a camper for about 50K of the 148,500
Oct 18, 2010 at 12:55 PM
  • 110,244 POSTS
Does the noise change when you make turns? Have you checked u-joints.
Oct 18, 2010 at 1:26 PM
ALEC TRICIAN
The noise is constant even when taking gradual turns on the freeway between those speeds, it does seem to be getting worse over the last 100 KMs or so, I've tried to physically move the drive shaft and just had the tires balanced and asked them to look for anything there but they said everything seemed tight, with no problems with the tires or rims.
Oct 18, 2010 at 4:17 PM
  • 110,244 POSTS
The only thing I would say is to have the front hub bearing checked. The differential isn't engaged when in 2wd, so the noise shouldn't be coming from there. Usually, a change in the sound is noticed when turning with wheel bearings.
Have them checked and let me know what you find.
Oct 19, 2010 at 2:00 PM
