2000 Chevy Silverado vibration
12,139 MILES • 6 CYL • 2WD • AUTOMATIC
DR_ZUES_ROSE
Sir: I own a chevy silverado 1500 2-wheeel drive ,6 cylinder truck.At 63 mph i have a definate vibration coming from my front end .I have had the tires balanced and rotated but it hasn't solved the problem .It doesnt pull to one side or the othr so i don't believe it's in the alignment but what are some of the other things that i can do to fix this problem ?Any information would be helpfull .Thank you for your time and conideration in helping me with this matter.
Aug 7, 2009 at 7:44 AM
JARMAN
If your ball joints and tie rods ends have no play, your alignment is good and you aren't noticing any abnormal tire wear, I would point you in the direction of your wheel bearings.
When all of the things listed above are ok. A constant humming/vibration sound that gets louder when you turn the wheel left or right is a good indicator that your wheel bearings are going.
Aug 11, 2009 at 6:09 PM
