2002 Chevy Silverado
DMCKINNON
  • 2002 CHEVROLET SILVERADO
  • V8
  • 88,000 MILES
I am getting a vibration between 55 & 65. I lowered the rear about 1.5 and had no problems for years. It started gradually and I had front end work done because that is what the shop said was the problem. It did not sove the issue. I was told to put angle shims to correct the angle. I called Stylin and they said that just lowering that much would not cause the problem. I had a 99 new body and lowered it the same and never had a sinle issue. Could you give me a couple of suggestions?
Friday, August 13th, 2010 AT 12:59 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Could be a tire issue, not suspension issue. Check tire wear and also sidewalls of tires, also have all tires balanced. If you have hit pothole lately one of the wheels may be bent causing the vibration as well.
Friday, August 13th, 2010 AT 1:45 AM
