HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Silverado
Engine
1998 Chevy Silverado changing an avaporator
ASHLET2000
MEMBER
1998 CHEVROLET SILVERADO
V8
2WD
AUTOMATIC
192,000 MILES
Can it be changed under the hood?
Monday, July 7th, 2008 AT 9:59 AM
DOCFIXIT
MECHANIC
Yes split the case some bolts are a trip to get at but it can be done. Disconnect accumulator and high side line first. When case is apart you wrangle the evap out.
Good luck
SPONSORED LINKS
Monday, July 7th, 2008 AT 10:16 AM
Please
login
or
register
to post a reply.
Related Engine Content
Engine Heat
The Engine Will Not Get Above 135 Degrees. I Have Replaced The Thermostat, The Temperature Sensor. The Radiator Hose On Return Side Is Hot...
Asked by
Edward Gonzalez
1 ANSWER
1 IMAGE
1998
CHEVROLET SILVERADO
GUIDE
Code Reading
A check engine light, also known as a service engine light, or a MIL (malfunction indicator light) is designed to let you know there is a problem with one of your car's...
1998 Chevy Silverado Engine Compatability
I Have A 98 Chevy Silverado Z71, With A V8 350 Vortec. The Engine And Trani Are Bad. I Found A 89 Suburban With A Working Engine And Trani...
Asked by
dwje2002
1 ANSWER
1998
CHEVROLET SILVERADO
2007 Chevy Silverado Information On 8.1 Litre Engine
2007 Chevy Silverado V8 Four Wheel Drive Automatic Can You Tell Me Anything About The 8.1 Litre Gas Engine Used In The 2007 Chev...
Asked by
Brian Bullen
1 ANSWER
2007
CHEVROLET SILVERADO
2006 Chevy Silverado Check Engine Light-fuel System
I Keep Getting A Check Engine Light. I Had A Mechanic Run The Codes And He Got Two Both Having To Do With The Fuel System. I Replaced The...
Asked by
dci520
2006
CHEVROLET SILVERADO
1994 Chevy Silverado Engine Information
Engine Mechanical Problem 1994 Chevy Silverado V8 Four Wheel Drive I Just Purchased A The Truck And Wanted To Put A New Engine In It...
Asked by
javi0sh
1994
CHEVROLET SILVERADO
VIEW MORE
SPONSORED LINKS
Hybrid Car
Fuel Economy
Hybrid Engine
Online car repair manuals
