Engine Mechanical problem
1994 Chevy Silverado V8 Four Wheel Drive
I just purchased a the truck and wanted to put a new engine in it. What type of Engine size or bolts do I need.
Tuesday, January 5th, 2010 AT 6:43 PM
MECHANIC
We always recommend staying with a direct fit parts. The reason is because everything chances when you change years, size. Sensors don't work, mounts need changed, vacuum hoses change, wiring chances.
What size engine is in the truck now?
SPONSORED LINKS
Thursday, January 7th, 2010 AT 8:17 PM
JOEAMOS101
MEMBER
I took a motor snd msnusl trans out of a 91 and everything on the motor was the same. I have had to change the trans in my 94 two times it is a one yr only trans beware
