1996 Chevy Silverado Will not start cold
CHEVYWILL
  • 1996 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 224,330 MILES
My trruck will not start cold unless fuel is applied through the intake. After that it runs fine.
Wednesday, January 7th, 2009 AT 11:17 PM
Do you hear the fuel pump come on for a few secs when key at run position?
Wednesday, September 2nd, 2020 AT 6:02 PM
CHEVYWILL
Yes I can hear the fuel pump making a noise, but does that mean it's working properly. The truck runs good after I pour gas in the intake to get it started. Also the truck will surge when operating at a steady speed. Any idea what the fuel line pressure should be? I will check that this weekend. Thanks
The pressure should be 60-66psi
CHEVYWILL
Thank you for your help. I'm about 99% sure it is the fuel pump. I will replace it this weekend and let you know. Thanks again. Will
CHEVYWILL
It was a combination of fuel pump and spark plug wires. Thank you rasmataz for your insight. You were correct about the fuel pump. It was making a noise but not the right kind of noise. Thanks again.
