Monday, February 15th, 2010 AT 11:00 PM
I am having trouble with my trouck starting when it is cold. In the morning or when it has sat for an hour or so, it cranks over fine, but just wont catch. I am forced to use starting fluid, which works and then the truck runs fine. As when it I start it still warm. I have new battery, cables, spark plugs and wires, new distributor, new ignition coil, new fuel filter and fuel pump. Have been told it may be crank sensor or cam sensor. Has anyone else run into this problem and what was the solution?
