Thanks for the quick reply. No, the high mount brake light doesn't work either, so I guess that still brings me back to the brake switch. I can't seem to find that switch. I would expect there would be some kind of linkage connecting the brake pedal to the switch, right? On my truck, it just looks like the brake pedal goes through the floor board. When I look on the other side (the engine compartment), everything is covered. Do you know if the brake switch is inside the cab or the engine side? Everything's pretty cramped in there, so it's possible I'm missing it, but I'm just not seeing it. Once I find the switch, I think I'll be good to go.
Friday, February 26th, 2021 AT 10:46 AM
