brake lights
180,000 MILES
BRIAN SAM NIPPER KNIEP
Replaced battery. No brake lights, Replaced brake light switch, cab brake light works but not tail light brakes.
Aug 18, 2016 at 1:53 AM
HMAC300
  • 48,601 POSTS
check t/s switch it may be that it is a yellow wire from brake light switch and one going to right taillight see if turn signals work if they do then it may be the ground on left hand rear frame rail.
Aug 18, 2016 at 2:20 AM
