1994 Chevy Silverado
MGOWEBER
  • 1994 CHEVROLET SILVERADO
Electrical problem
1994 Chevy Silverado 6 cyl Two Wheel Drive Automatic 160.00 miles
i replaced engine, when I finished install, tried to start and found no fire. I checked power to coil and had 12 volts there, where do I check next
Tuesday, January 12th, 2010 AT 3:37 AM
BLACKOP555
  • 10,371 POSTS
You have to check on the negative side to see if your getting a pulsing - voltage when cranking.
Do you get spark from coil directly? I dont know if you mean spark as fire or vehicle starting as fire.
Wednesday, September 2nd, 2020 AT 6:16 PM
