car wont start has spark and has fuel
170,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
RICHARD BRADSHAW
  • 7 POSTS
ive replaced the fuel pump, the rotor and cap, ignition module, and ignition coil. the car cranks but never starts, and gas does pump. not sure if it could be an electrical issue not giving a strong enough spark or maybe the ignition switch.
Mar 17, 2017 at 12:30 PM
CJ MEDEVAC
  • 11,000 POSTS
Did you remove the distributor?
Are you confident it went back in correctly?
Unsure? Maybe I can help.
You are ACTUALLY seeing spark?
The Medic
Sep 2, 2020 at 11:15 AM
RICHARD BRADSHAW
  • 7 POSTS
yes i am sure. both my dad and another guy came and both tested it for spark
CJ MEDEVAC
  • 11,000 POSTS
Roger on spark!
Rules out a New Bad Module.
If the distributor ain't in time with the with the pistons,
You will STILL get spark, At the Wrong Time!
Not questioning your abilities, but if you are bumping the engine with the starter to get to TDC, it's EZ to overrun your marks.
I'M COPYING AND PASTING this from a Jeep CJ post I answered (My Favorite vehicle)
DISREGARD the firing order! And other Jeep stuff (like the manual tranny) It's for the Jeep!
MAYBE A THIS IS A REVIEW BUT THESE ARE GOOD!
CLASS 1
http://www.youtube.com/watch?v=5a2X9mSSlQY
CLASS 2
http://www.youtube.com/watch?NR=1&v=FHX1yXVyIMg&feature=endscreen
now
if we got carried away bumping the starter - this way (below) will cut out possible "going too far with the timing marks
now that david and chad told you how
let's do it to slow motion
hide your keys/chock your wheels/ go to neutral
remove #1 spark plug
stick it back in , maybe 2 threads (instead of using your thumb)
rotate the engine with a wrench or ratchet (not the starter)
clockwise as viewed from the grill
when you hear the "hiss" coming by #1 plug=-=-=stop! ( a friend may be helpful to hear this at #1 (as the other cylinders hiss internally (usually fainter) when you rotate the engine manually
now, we are on/ beginning the compression stroke on #1 cylinder (piston is still coming up)
we ain't up yet!
ever so slowly rotate the engine (cw) till your timing mark (line) lines up with zero!
stop!!!
i have found that using the starter for the "bumpage" usually results in "overrunning" the marks, compression kicks it back, etc.
then you mistakenly rotate on around 180 degrees from where you should be (not sayin' bad things, but if you are new to this, it's an ez mistake!)
ok, back to our slow-motionage!
now look at the rotor button
it should be facing the "mark" you put on the 'stributor
.......or which ever tower you chose to be #1 (textbook or not)
the engine/ cam/ crank don't care which one it is!
as long as you were at tdc, you placed #1 spark plug wire on "that tower" (the one that rotor is pointing to)
and your 1-5-3-6-2-4 firing order starts there- and runs the sequence clockwise (looking down on the 'stributor cap)
installing it "textbook" cuts down on confusion later on, as you may have forgotten the "deal"- simply hooking it all up like it shows in the book will make it ezier in 8 months! (but you gotta install it textbook now!)
lets hears some info!
THE MEDIC
OK end of my pasting, Is it possible that it's the distributor, or the wires are, off in sequence?
Ruling out EZ stuff!
The Medic
RICHARD BRADSHAW
  • 7 POSTS
what i did was just took the old distributor put it next to the new one facing the same direction, then one by one i switched the cables over.
CJ MEDEVAC
  • 11,000 POSTS
OK New Cap- done right.
Distributor was never taken loose or out of the engine?
Have you tried a two second burst of starter fluid into the throttle body and an attempted start? What did it do?
The Medic
RICHARD BRADSHAW
  • 7 POSTS
thats the fun part no sogns as to what in the hell happened. 2 days ago i started it to go to work. everything fine, then about 4 hours later went to start it amd nothing. im suspecting the ignition trigger. my pump was bad but im thinking everything else i replaced (aside from the distributor cap) was ok.
my thinking is maybe sense the ignition switch activates the gas pump as well maybe there was a short or something that burnt it aswell because before i replaced the pump no gas got to the tb
CJ MEDEVAC
  • 11,000 POSTS
What about shooting fuel into the throttle body, does it 'TRY' or does it just do dry over and overs?
The Medic
RICHARD BRADSHAW
  • 7 POSTS
it shoots fuel but wont turn over and we confirmed there is spark
CJ MEDEVAC
  • 11,000 POSTS
Gotta get 'terms' a little corrector!
"Turns Over" means Cranks/ Cranking/ Crankshaft does revolutions using the starter/ hand crank/ pushing it off with the clutch
Runs/ 'busts off'/ 'it started up' means it is now moving due to internal combustion taking over!
Overlooking key questions or assuming I know 100%
You said
"What I did was just took the old distributor put it next to the new one facing the same direction, then one by one I switched the cables over."
I sorta really need to know was this JUST THE CAP or the ACTUAL DISTRIBUTOR that was swapped? Has the anchor been taken loose and the distributor picked up (even slightly)
3 NEEDS for engine to run
FUEL (real fuel)
SPARK (at the right time)
COMPRESSION (Kinda the last thing I check, unless a flag goes up)
Did you squirt in some starter fluid? (You know if you have a lot of water in your tank-IT SQUIRTS TOO- It just don't have any combustion value!
I ask these kinda questions/ perform simple tests to see which direction we need to attack.
When you don't do the test or give vague information I'm stuck here without a compass!
Re-read this post, Let's get the info I need.
The Medic
RICHARD BRADSHAW
  • 7 POSTS
excuse me i meant the cap sorry kind late for me haha
RICHARD BRADSHAW
  • 7 POSTS
there is no water in the system. the distributor was not touched just the cAp and rotor.
and dont worry i get why your asking questions im completely fine with it.
the vehicle will.crank but not start.
  • 55,845 POSTS
Lets get back to basics, First when you put the distributor back in did you mark it becasue if you pull it our it will not go back in the same way becasue of the oil pump drive rod, you either have to move the drive rod backwards slightly or move the distributor counterclockwise.
Here is a guide that might help
Best, Ken
CJ MEDEVAC
  • 11,000 POSTS
Ken,
Says the distributor was never touched,
Just the cap
I wonder if the roll pin on the distributor gear gave way? This would affect the firing order.
RICHARD BRADSHAW - can you 'Sternly' Not 'Forcibly' Try to turn the rotor button (the shaft included) with your fingers to see if it will move to another position. We Don't Wanna Break Nuthin'
IT SHOULD NOT TURN! (unless the gear on the other end has a problem)
A little CW and CCW movement is normal.
If you are up to it, we (you!) can Verify TDC and see if the rotor button is pointing at #1 post on the distributor cap. This will require taking #1 spark plug out. This is not a hard task. Lemme Know!
The Medic
