1992 Chevy Silverado Where to start?
THE UTILITY MAN 97
  • 1992 CHEVROLET SILVERADO
  • V8
  • 315,630 MILES
My Old Chevy just stop running on me the other day. I was driving and it just died and wouldn't even start. It will turn over but she won't run. I was think the fuel pump since it started fine that morning ran fine up until it just died. How can I test the to see if it's the fuel pump?
Saturday, July 11th, 2009 AT 1:21 PM
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_92_chevy_1.jpg
When you first turn the key on, no crank, can you hear the pump for a couple of seconds? Are there any codes? You can run the pump without using the key, terminal G at the datalink connector, it should look like the above picture. Use a jumper with an inline fuse connected to B+ touch the G terminal, the pump should run. Also you need a fuel pressure gage on the supply line, to check pressure. I've seen injector spray patterns that looked good to me while cranking, but the pressure was half of what it should have been.
You could try starter fluid in the TBI, see if it will try to start? There could be safety issues using a flammable spray, the responsibility is yours.
Thursday, September 3rd, 2020 AT 9:24 AM
