1992 Chevy Silverado oil pressure
JAKECAN2
  • 1992 CHEVROLET SILVERADO
  • V8
  • 232,000 MILES
My oil pressure drops to zero and the engine starts "tinging" whats the problem. The oil pressure comes back and the tinging stops. It is pretty cold outside -40.
Saturday, January 24th, 2009 AT 4:12 PM
-40deg can do a lot of weird things-what is the oil vicosity your using and was the last oil/filter change?
Saturday, January 24th, 2009 AT 4:26 PM
JAKECAN2
  • 10 POSTS
Im using 10w30 full synthetic.
Saturday, January 24th, 2009 AT 4:27 PM
That cold even a 5W20 will cause the oil pump to have a hard time pushing the oil through out the engine-Its just the cold-Do you hear knocking noises when its happening-if so check the oil pressure with a mechanical gauge
Saturday, January 24th, 2009 AT 6:06 PM
JAKECAN2
  • 10 POSTS
Its been colder the past few days and its run fine, it used to run 30PSI now it is either 0 or 15. In between during driving 15 at idle, then 0 when ever it wants.
Saturday, January 24th, 2009 AT 6:24 PM
Sounds like the oil pressure sending unit is out of calibration-could also be the oil pump sticking-check the oil pressure with a mechanical gauge.
Saturday, January 24th, 2009 AT 6:45 PM
SCOTTISH
  • 16 POSTS
I think your oil pump is craping out
Saturday, January 24th, 2009 AT 9:32 PM
The only way for him to find out is to hook up the gauge and read off
Saturday, January 24th, 2009 AT 9:41 PM
Causes of Low Oil Pressure that will trigger the oil light
Possible causes include:
Excessive main and rod bearing clearances (someone may have installed the wrong-sized bearings or standard-sized bearings on a reground crankshaft). Only 0.001" of extra clearance in the main bearings can reduce oil pressure by up to 20%!
Excessive camshaft bearing clearances (a bearing may have slipped out of place when the cam was installed).
Excessive clearances inside the oil pump.
Leaks between the oil pump and engine.
Oil pump relief valve stuck open or installed backward.
A loose or mispositioned oil pickup tube (too high in the oil pan).
A defective oil pressure sending unit or oil pressure gauge.
Low oil level in the oil pan.
Cracks or leaks in the oil galleries or gallery plugs.
Cracked oil pump housing (improper installation).
Oil viscosity too thin for hot weather.
Oil viscosity too thick for cold weather.
Saturday, January 24th, 2009 AT 9:48 PM
