Engine is not running? Starter is working
125,000 MILES • V8 • 4WD • AUTOMATIC
C. MORRIS
Truck will not start after checking plugs. Also the truck is using a lot of oil. ??
Feb 1, 2009 at 8:38 AM
  • 110,251 POSTS
Are you sure you have the plug wires replaced in the correct order? When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Feb 2, 2009 at 4:39 AM
C. MORRIS
Yes. The plug wires were on the correct plugs. The truck started fine the next day without me touching anything.
Feb 3, 2009 at 10:08 AM
  • 110,251 POSTS
That is good news. You said after the tune up it wouldn't start, so the only thing I could think of is wires. Regardless, I'm glad it's running.
Let us know if you have any questions in the future.
Feb 3, 2009 at 10:20 AM
