1991 Chevy S-10 White Smoke Uses Water
DUNN_212003
i have a 1991 chevy s10. its manual transmission. blows white smoke and uses alot of water. the engine runs quiet. smells like there is gas in the oil. when i pull the dip stick out you can smell it. can you help me? what could it be and what can i do? thanks.
Nov 10, 2007 at 2:34 AM
  • 75,988 POSTS
White smoke plus uses too much water/coolant is a sign of blown headgasket or could also be a crack head or block.
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Nov 10, 2007 at 2:41 AM
Suggested Repair
Have the block tested first for combustion leaking into the cooling system, or sniff the radiator neck for hydrocarbons. Suspect a blown head gasket, cracked head, or cracked block. Do not pressure-test if the head gasket is already leaking, because coolant can enter the cylinders. If those tests pass, check the thermostat, radiator cap, radiator, fan clutch, electric fan, hoses, and water pump.
Conversation Summary
The owner of a 1991 Chevy S-10 reports white smoke, high water use, a quiet engine, and a gasoline smell in the oil. The expert says this points to a blown head gasket, cracked head, or cracked block, and recommends block testing or a hydrocarbon check at the radiator before other cooling-system checks.
