1998 Chevy S-10 White smoke coming from the exhaust?
CHEVY619
  • 1998 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 140,000 MILES
I was wondering if you can suggest any problems that might cause the white smoke from the exhaust? Head gasket? Pistons?
Wednesday, March 5th, 2008 AT 7:08 PM
SERVICE WRITER
  • 9,123 POSTS
Typically it is coolant burning. Maybe headgasket, intake gasket? Sometimes you will see bubbles coming up through the radiator that are from a headgasket leak.
IF you pull the plugs and pressure test the cooling system for about 5-10 minutes, then spin the engine over with the plugs out, coolnat may shoot out the plugs hole to help confrim the leak.
Wednesday, March 5th, 2008 AT 7:52 PM
