Slave Cylinder
INDYGUY32
hello this is my first post... : )
I have a 98 chevy s-10 pickup with a 5 speed and 2.2L
when its summer time my clutch is fine i have added clutch fluid maybe 4 times all summer but as soon as it gets to about 40 deg outside i have to add fluid every day.....does this sound like a bad O ring on my slave cylinder.....clutch still works great just leaks
any help would be greatly appreciated.
Sep 11, 2007 at 12:39 PM
  • 31,937 POSTS
Hi there,
If you are adding fluid that often you do have a leak, peel back the rubber boot on the slave cyl and if there is fluid present the cyl should be replaced, to check the master cyl is a bit harder, look up under the dash where the pedal rod is and have a good look for signs of fluid leaking out of the master cyl.
good luck,
Mark (mhpautos)
Sep 11, 2007 at 5:05 PM
