1995 Chevy S10 Stiff Clutch Pedal
BILDO76
  • 18 POSTS
I have a 95 Chevy S10 with 4.3 V-6 . The truck has about 198,000 miles on it. When I got the truck the hydraulic clutch was very stiff and it didnt release well until it was all the way down also when it was in gear it would engage just off the floor. When I pulled the trans out of it the pivot ball for the clutch arm had almost completely wore thru the clutch arm! I replace the pivot ball,clutch arm,clutch,pressure plate,throw out bearing,pilot bushing,throwout bearing retainer(quill) and had the flywheel resurfaced. Seeing the shape that the clutch arm was in I felt I found my problem. But when I got everything back together the clutch works a little better but I have the same problem. The clutch still engages just off the floor with the truck in gear and dont release until it is on the floor. Plus I still have a stiff clutch pedal. I was wondering if a clutch master cylinder could cause these problems?? Any help would be great!
Thanks,
Bill
Feb 9, 2007 at 9:25 AM
2CARPRO JACK
  • 11,533 POSTS
It could. Unhook the clutch master arm to be sure the pedal travels freely on its own.If there is an adjustment on the rod for th emaster, adjust it to give some free-play in the pedal
Feb 10, 2007 at 11:58 PM
MIKE H R
  • 3,094 POSTS
you could try bleeding the hydraulic clutch system.
it is some what like bleeding brakes. but is the clutch
uses brake fluid and is located on the left side under the vehicle
Feb 11, 2007 at 2:34 AM
Suggested Repair
Unhook the clutch master cylinder arm and confirm the pedal travels freely. If the master rod is adjustable, set it for some pedal free play. Also bleed the hydraulic clutch system, which uses brake fluid.
Conversation Summary
The owner of a 1995 Chevy S10 with a 4.3 V6 replaced the worn clutch arm, pivot ball, clutch, pressure plate, throw-out bearing, pilot bushing, and quill, and had the flywheel resurfaced. The pedal is still stiff, the clutch engages just off the floor, and it does not release until the pedal is fully down. The expert says the master cylinder could cause this and recommends checking free pedal travel and adjusting the master rod for free play. Another reply suggests bleeding the hydraulic clutch.
