1973 Chevy Truck Length of travel on clutch pedal
1973 CHEVROLET TRUCK
178,000 MILES • V8 • 2WD • MANUAL
NUTBAG01
I recently bought an old chevy truck.1973 Chevy Custom30,350 V8,4 speed w/granny gear.Clutch pedal goes in about 12 inches(estimate)shifter goes into gear fine but pedal comes out about 10 inches before the clutch begins to bite.Once it hits that spot it engages great.Is there any way of adjusting the linkage???
Jun 14, 2009 at 11:34 AM
DR LOOT
  • 2,311 POSTS
the clutch linkage on that truck is totally adjustable you will just have to look at it and see where to adjust it but I don't think that's the problem, the truck is very old and most likely the linkages are wore out, check online because they make every part new on that truck you should not have any problems finding new linkage parts and bushings
Jun 19, 2009 at 3:42 AM
