fuel system
JBIRD69
I have a 1995 s-10 pickup and i bought a brand new fuel pump, sending unit, and fuel tank and it will not start. I tested the fuel pump and it works when i touched it to battery positive post and if i leave it their it will run and i can crank it up. But otherwise when turning on the key i can not hear the fuel pump running and it will not start what can be the problem?
Jun 5, 2007 at 12:36 AM
MIKE H R
  • 3,094 POSTS
check the fuses , check the fuel pump relay
Jun 5, 2007 at 4:29 AM
CARGAL
Did you check to make sure you reattached the ground wire?
Sep 28, 2007 at 2:03 PM
