2000 Chevy S-10 fuel pump will not work
METZIROCZ
  • 2000 CHEVROLET S-10
Electrical problem
2000 Chevy S-10 4 cyl Two Wheel Drive Automatic
Fuel pump will not work, all fuses and relays are good and clicking when the key is turned forward, but pump will not prime or work when trying to start truck?
Wednesday, October 6th, 2010 AT 2:34 PM
ECM B 20 amp fuse okay-try this power the gray wire on the fuel pump connector direct from the battery positive terminal and see what happens if it comes on -go back to the fuel pump relay and retest
Wednesday, October 6th, 2010 AT 2:49 PM
