1999 Chevrolet S-10 Fuel Pump Not Working Fix
GASJOCKEY
1999 Chev S10, 4.3L, 175,000km, 2wd, auto.
I just purchased the truck, was told it needed a new rad and fuel pump, it didn't start when it was damp outside.
I drove the truck a couple of days, then changed the rad, fired up the truck and changed coolant.
I then changed the plugs, wires (identified each, should not be any problem there), cap & rotor.
Truck would not start, it was late in the evening and somewhat damp.
The next day, I checked fuel pressure on the line, 0 reading. then checked fuses (OK), changed relay with several others from the fuse block (no change).
I then pulled the bed to work on the fuel pump. There are seven wires @ the tank, four to the pump/gauge assembly and three to another block??. Voltmeter shows 5.14V on one gauge terminal and the same on the gray wire on other block, no voltage to pump. I then ran direct from the battery to the pump, +positve to the gray wire, -negative to the black wire, pump did not work. Help!
Steve
Hamilton, On
Sep 16, 2007 at 1:14 PM
  • 75,988 POSTS
[quote:308f1bc038="gasjockey"]1999 Chev S10, 4.3L, 175,000km, 2wd, auto.
Steve
Hamilton, On[/quote:308f1bc038]
If you feeding it with direct battery power and not coming On its dead
Sep 16, 2007 at 2:09 PM
Suggested Repair
Replace the fuel pump. Direct battery power did not make it run, so the pump is dead.
Conversation Summary
A 1999 Chevrolet S-10 with a 4.3L would not start and showed zero fuel pressure. Fuses and the fuel pump relay were checked without restoring power to the pump. Applying battery power directly to the pump wires also failed to run it, and the expert concluded the pump is dead.
