2001 Chevrolet S-10 Fuel Pump Dead
WAYNE5995
i have a 01 s10 with a 2.2 4 cly. the fuel pumped stopped working (the truck ran fine the day before) i spent 390 .00 on a new one thinking the pump was bad after replacing the old plump the new pump still does not work the truck only hsas 51 k on it i have spark at the plugs, the engine cranks fine but still fuel is reaching the injectors. no humming at the pump i checked the filter also but no fuel there either yes there is gas in the tank could the relay go bad in the fuse box? im at a total loss
Apr 11, 2007 at 11:43 AM
BACKYARDMECHANIC
  • 337 POSTS
The relay can and does go bad, but before replacing it check the fuel pump fuse first. Good luck
Apr 11, 2007 at 11:51 AM
WAYNE5995
where is there a fuse for the pump i've checked on the fuse box lid i couldnt find one listed
Apr 11, 2007 at 12:06 PM
Suggested Repair
Check the fuel pump fuse before replacing the fuel pump relay. The relay can fail, but the fuse should be verified first.
Conversation Summary
The owner of a 2001 Chevrolet S-10 with a 2.2 four-cylinder says the fuel pump stopped working overnight. A replacement pump still does not run or deliver fuel to the filter or injectors, although the engine cranks, the plugs have spark, and the tank has fuel. The expert says the relay can fail but advises checking the fuel pump fuse first. The owner could not find a pump fuse listed on the fuse box lid.
