89 s10 blazer Acceleration problem
JEFFROFALS
I have a 1989 s10 blazer, 4.3L v6, 2WD Automatic. 222561 kilometers. Whenever I press the accelorator it seems to hesitate for a second before actually accelerating. Also sometimes usually when taking a corner the accelerator will not respond when being pressed and and slow downfor 3-4 seconds until it seems to catch and then go. I have had the muffler, exhaust, tailpip, cat convertor, fuel & oil filter, oil, spark plugs and wires replace within the last 3 months. What might be causing this?
Nov 22, 2007 at 2:51 PM
PEAR69
  • 1,482 POSTS
Is it fuel injected or carburated? How's the oil pressure? check the oil level. Did the truck do this before you had the above mentioned done? I know this question may be silly but I must ask--Is there enough gas in it? Don't get mad--just askin'.BTW you can check if it's injected or carburated by taking the air cleaner lid off and observing the thing in the middle of it. If the thing has 1 or 2 things that look like eggs in the middle and before the butterfly valve then it's injected;the thing is called a throttle body and the egg or eggs are the injectors. This system is a T.B.I. system ( Throttle Body Injection).If not then it's an old carburator..but I dought it..Let me know
Nov 22, 2007 at 3:18 PM
