1989 Chevy S-10 Stalling
GLWEST
  • 1989 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 132,000 MILES
Engine will start fine. It will run for about 15 seconds at high idle and then idle down and run rough and die. When I keep trying revving engine and the warms up some it will run like a new truck. At first I thought it was an EGR valve problem and replaced it. Aso checked for vacuum hose leaks. Any suggestions?
Sunday, January 13th, 2008 AT 11:32 AM
MERLIN2021
  • 17,250 POSTS
If it won't idle normally after it's warm, check the idle air control valve, it's bolted to the side of the throttle body.
Sunday, January 13th, 2008 AT 11:37 AM
