I relaced the brake pads. They were worn, but not metal to metal. The rotors could use a cut, not horendous but a little grooved. After assembly, the truck now makes a noise like something is loose, but the lug nuts and brake mounting bolts are tight. The noise goes away, when you lightly press on the brake pedal.
SPONSORED LINKS
Sunday, May 9th, 2010 AT 6:59 PM
