1999 Chevy S-10 Lug bolt
SUN2RAIN2SNOW
  • 5 POSTS
Tires and Wheels problem
1999 Chevy S-10 6 cyl Four Wheel Drive Automatic
How to take stripped lug bolt out
Jun 27, 2010 at 2:08 AM
MMPRINCE4000
  • 8,548 POSTS
You can rent a tool at most autoparts stores (large "C" clamp) to remove studs.
Jun 27, 2010 at 2:14 AM
SUN2RAIN2SNOW
  • 5 POSTS
Cannot get get stripped lug nut out, using a tire cross bar doesn't work, the tire/rim is still on truck, and need to change rotors, brake pads.
Jun 28, 2010 at 12:19 AM
MMPRINCE4000
  • 8,548 POSTS
Studs are pressed in, the "C" clamp has a large reciever at on end, you simply turn clamp bolt to remove stud.
Jun 28, 2010 at 1:53 AM
