Disconnect the negative battery cable.
Drain the engine cooling system.
Relieve the belt tension and remove the accessory drive belts or the serpentine drive belt, as applicable.
Remove or disconnect the following:
NOTE
For the hoses on some engines, removal may be easier if the hose is left attached until the pump is free from the block. Once the pump is removed from the engine, the pump may be pulled (giving a better grip and greater leverage) from the tight hose connection.
WARNING
Note the positions of all retainers as some engines will utilize different length fasteners in different locations and/or bolts and studs in different locations.
Upper fan shroud
Fan or fan and clutch assembly, as applicable
Water pump pulley
Coolant hose(s) from the water pump
Water pump retainers
Water pump from the engine
Clean the gasket mounting surfaces.
NOTE
The water pumps on some of the earlier engines covered may have been installed using sealer only, no gasket, at the factory. If a gasket is supplied with the replacement part, it should be used. Otherwise, a 1 / 8 in. (3mm) bead of RTV sealer should be used around the sealing surface of the pump.
Apply sealant to the water pump retainer threads.
Install or connect the following:
Water pump using a new gasket.
Tighten the water pump retainers to 18 ft. Lbs. (25 Nm) for 2.2L engine or to 30 ft. Lbs. (41 Nm) for 4.3L engine.
Coolant hose(s)
Water pump pulley
Serpentine drive belt (if equipped) by positioning the belt over the pulleys and carefully allow the tensioner back into contact with the belt V-belts (if equipped) and adjust the tension
Upper fan shroud
Negative battery cable
Refill the engine cooling system.
Run the engine and check for leaks.
SPONSORED LINKS
Tuesday, August 25th, 2009 AT 12:50 PM
