1999 Chevy S-10 Coolant Leak
BIKERBEN
  • 1999 CHEVROLET S-10
  • 6 CYL
  • MANUAL
  • 89,000 MILES
My S10 Blazer has a coolant leak. I can smell the coolant when the truck is running and, when parked, a puddle can be found beneath the left, rear side of the engine. It's very tight in that area, with the steering shaft, brake master cylinder and associated tubing in the way, and from underneath, the exhaust manifold and pipes are in the way. So I can't visually see where the leak is coming from. When the truck is run and then left overnight, coolant continues to drip slowly all night long. Any ideas?
Wednesday, March 10th, 2010 AT 7:12 AM
DOCFIXIT
  • 18,828 POSTS
Hi maybe a freeze plug have you tried jacking up and have a look. Also could be intake manifold leaking at rear try using an inspection mirror to help see in tight spots.
Let me know
Thanks for donate
Saturday, October 3rd, 2020 AT 11:15 AM
