1999 S-10 sometimes dies after start, when you give it gas
LITHRAEL
Hey, I'd really love some help with this one, mechanics keep 'fixing' it, it happens again...
1999 Chevy S10 pickup, automatic, just hit 90,000 miles. Replaced alternator 2 years ago.
Simple version:
The car runs fine in neutral no matter how much gas you give it, and seems fine in gear until you really step on the gas, and then it dies. Sometimes it acts like the battery is almost dead. This only happens once in a while and seems fine after a visit to the mechanic.
Full version:
This has happened three times over a year, all slightly different. My memories about the battery might not be right.
1 year ago, it wouldn't start, battery seemed dead, got a jump and the car started and idled fine for a while, drove a few feet and then died. Shop told me the computer was cutting the engine due to a fuel pressure problem. Cleaned fuel system & changed fuel filter, didn't have the problem again.
A few months ago, it wouldn't start, battery seemed low. Got a jump and the car started and idled fine for a while, drove a few feet and then died. Shop said they couldn't find anything wrong but bad battery contacts, said my battery was due for replacement anyway & put a new one in. Didn't have the problem again.
Last night it started up on its own but was acting strange, drove a few inches and then died. Wouldn't start again. Got a jump, made it home ok. This morning, started up on its own, backed out of the driveway, put it in drive and hit the gas, it died. Currently starts and idles fine, haven't tried to drive it anywhere, but doesn't seem to be stalling right now. In neutral, sounds normal, with a slight vibration when I give it a lot of gas.
Was it an intermittent spark plug problem or a broken steering column wire all along, with shops fixing other things? Or? Don't know what to tell them to look for when I take it in this time. Worried it will happen on the Atlanta highway.
Other related (?) issues: headlamp light sensor doesn't work, headlamps are on all the time, headlamp fuse gets hot. Very easy to 'miss' ignition position with the key (turn past it). When the key is removed, the temp, oil, fuel guages seem to come back on after about 20 seconds (the needles pop back up, but not all the way to the reading they give when turned on normally).
Thanks for any help you can give me!
Sep 2, 2007 at 1:21 PM
  • 75,988 POSTS
[quote:116a95c5ef="Lithrael"]Hey, I'd really love some help with this one, mechanics keep 'fixing' it, it happens again...
Thanks for any help you can give me![/quote:116a95c5ef]
Man am almost confused-reading it. Putting it all together it sounds like an ignition switch problem.
Sep 2, 2007 at 10:28 PM
LITHRAEL
[quote:b29e5c1ea7="rasmataz"]Man am almost confused-reading it. Putting it all together it sounds like an ignition switch problem.[/quote:b29e5c1ea7]
Yeah, it is confusing, thanks for slogging through it!
I'll have them take a look at the ignition switch, see if it's the real culprit.
I keep thinking it's a fuel pressure problem because the car runs fine in neutral no matter how much gas you give it, and seems fine in gear until you step on the gas, and then it dies. But there's all the wierdness with the electrical power that goes with it.
Thanks again!
Sep 3, 2007 at 9:23 AM
  • 75,988 POSTS
[quote:595b9aa7da="Lithrael"][quote:595b9aa7da="rasmataz"]Man am almost confused-reading it. Putting it all together it sounds like an ignition switch problem.[/quote:595b9aa7da]
Thanks again![/quote:595b9aa7da]
Sir
While you're there have them look at the throttle position and MAF or BMAP sensors the one that measures the airflow going thru the engine with a scan tool.
Sep 3, 2007 at 11:50 AM
LITHRAEL
[quote:f4313c78f5="rasmataz"]While you're there have them look at the throttle position and MAF or BMAP sensors the one that measures the airflow going thru the engine with a scan tool.[/quote:f4313c78f5]
Thanks. Had it looked at yesterday. They couldn't find anything wrong there, or with the ignition, or with anything. $44 for computer diagnostics too and they haven't got a clue what might be wrong. Third mechanic I've seen with this little Chevy. Sigh! At least it's driving fine again right now. Thank goodness for AAA.
If anyone has an idea, I can always use more advice for the next mechanic, heh!
Sep 5, 2007 at 3:40 AM
  • 75,988 POSTS
[quote:778c19ea07="Lithrael"][quote:778c19ea07="rasmataz"]While you're there have them look at the throttle position and MAF or BMAP sensors the one that measures the airflow going thru the engine with a scan tool.[/quote:778c19ea07]
If anyone has an idea, I can always use more advice for the next mechanic, heh![/quote:778c19ea07]
At least it's driving fine again right now: Could be bad gas, a problem with IACV or dirty fuel injector/s or low pressure to it, fuel pressure regulator/clogged-up fuel filter-get the fuel pressure check.
Also could be the CTS giving the PCM the wrong signal and upsetting the A/F mixture.
Sep 5, 2007 at 7:44 AM
LITHRAEL
[quote:942d142bea="rasmataz"]At least it's driving fine again right now: Could be bad gas, a problem with IACV or dirty fuel injector/s or low pressure to it, fuel pressure regulator/clogged-up fuel filter-get the fuel pressure check.
Also could be the CTS giving the PCM the wrong signal and upsetting the A/F mixture.[/quote:942d142bea]
Cool, I'll keep a note of that for the next time it gives me trouble. I've had worse cars, yeah!
This place is great, thanks for all the attention.
Sep 6, 2007 at 10:41 AM
