1997 Chevy S-10 fuel pressure
CWROBSON
Engine Performance problem
1997 Chevy S-10 4 cyl Two Wheel Drive Manual
Where is the fuel pressure Schrader valve on this model pickup?
Thankyou in advance -
Rob
PostScript -----------
This is a multiport system, and we can't find the valve anywhere on the fuel rail. This may not be the original engine; did GM put the valve somewhere else in other years?
Thanks -
Rob
Sep 26, 2009 at 6:08 AM
  • 75,988 POSTS
Is it a TBI or MPFI fuel system?
TBI-disconnect the fuel line between the TB and fuel filter hook up the gauge-
MPFI-the schrader valve is on the fuel rail
Sep 26, 2009 at 6:32 AM
CWROBSON
[quote:0d27701e3b="rasmataz"]Is it a TBI or MPFI fuel system?
MPFI-the schrader valve is on the fuel rail[/quote:0d27701e3b]
It is an MP system, and we're not positive this is the original 1997 engine. But we cannot find the valve anywhere on the rail; did GM put the valves anywhere else in other years?
Thanks - Rob
Sep 26, 2009 at 7:13 AM
CWROBSON
It is a MultiPort system, and we're not positive this is the original 1997 engine. But we cannot find the valve anywhere on the rail; did GM put the valves anywhere else in other years?
Thanks - Rob
Sep 27, 2009 at 3:53 AM
  • 75,988 POSTS
It has to have one if it has a fuel rail if not backtrack to the fuel fuel filter and try to take it there.
Sep 27, 2009 at 5:26 AM
